- SamubaldehSoy nuev@ aquí
Fecha de inscripción : 17/07/2021
Mi RKV no se pone en marcha
Jue Jul 22, 2021 1:09 pm
Hola buenas, Puede parecer una pregunta un poco simple pero resulta que mi rkv no se pone en marcha , el display y las luces tienen una potencia muy baja, hasta el punto que ahora mismo no se encienden, que no se ponga en marcha mi Rkv es un problema de batería, no, que habrá muerto?
Gracias de antemano
Gracias de antemano
- jbailosKeewayero Experto
Edad : 60
Re: Mi RKV no se pone en marcha
Jue Jul 22, 2021 2:01 pm
Pues todo indica que sí.
[ltr] TRANSLATE with x
English
[/ltr]
[ltr]
var LanguageMenu; var LanguageMenu_keys=["ar","bg","ca","zh-CHS","zh-CHT","cs","da","nl","en","et","fi","fr","de","el","ht","he","hi","mww","hu","id","it","ja","tlh","ko","lv","lt","ms","mt","no","fa","pl","pt","ro","ru","sk","sl","es","sv","th","tr","uk","ur","vi","cy"]; var LanguageMenu_values=["Arabic","Bulgarian","Catalan","Chinese Simplified","Chinese Traditional","Czech","Danish","Dutch","English","Estonian","Finnish","French","German","Greek","Haitian Creole","Hebrew","Hindi","Hmong Daw","Hungarian","Indonesian","Italian","Japanese","Klingon","Korean","Latvian","Lithuanian","Malay","Maltese","Norwegian","Persian","Polish","Portuguese","Romanian","Russian","Slovak","Slovenian","Spanish","Swedish","Thai","Turkish","Ukrainian","Urdu","Vietnamese","Welsh"]; var LanguageMenu_callback=function(){ }; var LanguageMenu_popupid='__LanguageMenu_popup';
[url=javascript:Microsoft.Translator.FloaterShowEmbed()] [/url] [url=javascript:Microsoft.Translator.FloaterShowSharePanel()] [/url]
TRANSLATE with
COPY THE URL BELOW
[url=javascript:Microsoft.Translator.FloaterOnShareBackClick()] Back[/url]
EMBED THE SNIPPET BELOW IN YOUR SITE
Enable collaborative features and customize widget: Bing Webmaster Portal
[url=javascript:Microsoft.Translator.FloaterOnEmbedBackClick()]Back[/url]
var intervalId = setInterval(function () { if (MtPopUpList) { LanguageMenu = new MtPopUpList(); var langMenu = document.getElementById(LanguageMenu_popupid); var origLangDiv = document.createElement("div"); origLangDiv.id = "OriginalLanguageDiv"; origLangDiv.innerHTML = "ORIGINAL: "; langMenu.appendChild(origLangDiv); LanguageMenu.Init('LanguageMenu', LanguageMenu_keys, LanguageMenu_values, LanguageMenu_callback, LanguageMenu_popupid); window["LanguageMenu"] = LanguageMenu; clearInterval(intervalId); } }, 1); [/ltr]
English
[/ltr]
[url=#ar]Arabic[/url] | [url=#he]Hebrew[/url] | [url=#pl]Polish[/url] |
[url=#bg]Bulgarian[/url] | [url=#hi]Hindi[/url] | [url=#pt]Portuguese[/url] |
[url=#ca]Catalan[/url] | [url=#mww]Hmong Daw[/url] | [url=#ro]Romanian[/url] |
[url=#zh-CHS]Chinese Simplified[/url] | [url=#hu]Hungarian[/url] | [url=#ru]Russian[/url] |
[url=#zh-CHT]Chinese Traditional[/url] | [url=#id]Indonesian[/url] | [url=#sk]Slovak[/url] |
[url=#cs]Czech[/url] | [url=#it]Italian[/url] | [url=#sl]Slovenian[/url] |
[url=#da]Danish[/url] | [url=#ja]Japanese[/url] | [url=#es]Spanish[/url] |
[url=#nl]Dutch[/url] | [url=#tlh]Klingon[/url] | [url=#sv]Swedish[/url] |
[url=#en]English[/url] | [url=#ko]Korean[/url] | [url=#th]Thai[/url] |
[url=#et]Estonian[/url] | [url=#lv]Latvian[/url] | [url=#tr]Turkish[/url] |
[url=#fi]Finnish[/url] | [url=#lt]Lithuanian[/url] | [url=#uk]Ukrainian[/url] |
[url=#fr]French[/url] | [url=#ms]Malay[/url] | [url=#ur]Urdu[/url] |
[url=#de]German[/url] | [url=#mt]Maltese[/url] | [url=#vi]Vietnamese[/url] |
[url=#el]Greek[/url] | [url=#no]Norwegian[/url] | [url=#cy]Welsh[/url] |
[url=#ht]Haitian Creole[/url] | [url=#fa]Persian[/url] |
TRANSLATE with
COPY THE URL BELOW
Jue Jul 22, 2021 6:34 pm
Probablemente, pero seria bueno ver porque no tiene batería, porque simplemente se agoto su vida útil o porque hay atrás algún problema con el sistema de generación y recarga.Samubaldeh escribió:Hola buenas, Puede parecer una pregunta un poco simple pero resulta que mi rkv no se pone en marcha , el display y las luces tienen una potencia muy baja, hasta el punto que ahora mismo no se encienden, que no se ponga en marcha mi Rkv es un problema de batería, no, que habrá muerto?
Gracias de antemano
